Salta al contenuto principale
Lo Huawei P8 Lite (Modello: ALE-L21), annunciato nell'aprile del 2015, punta sulla bellezza nella semplicità. Le sue fotocamere professionali permettono di scattare foto naturali e nitide anche in ambienti poco luminosi. La modalità beauty abbellisce il viso del proprietario in ogni selfie.
20 Domande Visualizza tutte
wifi and blutooh greyed out
I got Huawei p8 lite and the wifi and bluetooth is greyed out. cant even turn on both the icons. I tried rebooting and factory settings, nothing worked out. can someone help me suggesting a solution. cant go for a new phone now.
Questa è una buona domanda?
Punteggio 8
3 Commenti
Im also having the same issue. The phone shutdown and when i turned it back on the wifi/bluetooth stopped working. Wifi can be switched on scans for available network but cannot see any, though my other devices are connected to the same router. There is another P8 Lite phone connected. Router has been rebooted and reset. Same thing happens to BT it wont see other BT enabled devices and other phones cant see the device. I have already rebooted the phone, checked wifi settings, Wipe Cache Partition several times and even did a Factory Reset but it didn't seem to help.
Device model ALE-L02
da
Same here - any help pretty please???
da
Same here any help please
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
@karyn Check that the phone is not in airplane mode WiFi and Bluetooth are disabled in airplane mode. Hope this helps
Punteggio 4
2 Commenti:
Sorry but this does not help
da
Still not work
da
Is there anyone found a fix?
Punteggio 0
1 Commento:
It can't connect
da
It's a chronical problem for p8 lites. It must be changed Wi-Fi Bluetooth IC.
Punteggio 0
Aggiungi la tua risposta
Ancy Baby Thomas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 12,499
