Salta al contenuto principale
Modello A1311 / Metà 2011 / Processore Core i5 da 2,5 e 2,7 GHz o Core i7 da 2,8 GHz
432 Domande Visualizza tutte
Mid 2011 iMac display not working
I have a mid 2011 imac. The display stopped working. The first diagnosis light is off whereas the other lights are on. Could you please tell me what the problem is?
I tried connecting secondary monitor but it did not work.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
From the sounds of it I suspect your real issue is the displays backlight.
What I think is confusing you is the external display is not working. Are you sure you have it setup correctly and using the good cable?
Instead of worrying about the external display take a flashlight and holding it on the display at a sharp angle are you able to see the faint image of your desktop icons? If you are they the display is working correctly (which the diagnostic LED's are also telling me as well).
Here is the IFIXIT guide to replace the backlight driver board: iMac Intel 21.5" EMC 2428 LED Driver Board Replacement. Before you go down this path make sure the cable connections are correct (if you opened the system).
Punteggio 1
Aggiungi la tua risposta
Prakash sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,104
