My laptop shutdown in every 30 to 40 minutes
my laptop shutdown in every 30 to 40 minutes and when i try to start again blue screen apear and system restart after trying 3 or 5 times its start
Questa è una buona domanda?
@valvi31, nitin , Could be overheating. Use the link below, a guide to dismantle your laptop so you can clean your computer inside. The fans and board may have accumulated a lot of dust, not allowing heat to dissipate properly causing it to over heat and shut down, the 3rd and 4th link will show how to clean. Good luck.
https://www.youtube.com/watch?v=c8HU06L4...
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 270
1 Commento
It could be a thermal issue with the CPU, the laptop will shut down if it detects overheat problems. It also could indicate that the thermal detection has gotten too sensitive which would indicate a bad mother board.
da DrGlowire
