Salta al contenuto principale
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
Do you have a guide for replacing the LCD and the LCD cover?
On my Canon PowerShot G11, the LCD is broken and the case that holds the LCD is dented. I need to replace the LCD and the case as a unit. Do you have a guide for doing this? If not, is this something that I can figure out based on your guide for replacing the rear cover?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@jthomson29 this should work for you:
You may have to do a bit of searching but every now and then parts are available at places like this.
Punteggio 1
I am pretty sure you could figure it out from the rear cover replacement guide, it looks like it is just two or so more screws then it comes off. The problem is going to be finding a replacement that comes as the whole unit not just the screen.
Punteggio 0
Aggiungi la tua risposta
Jim Thomson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 356
