Salta al contenuto principale
Kwickset door handle set with in-knob keyhole.
How do I disassemble the Kwikset Key-In Knob Locket?
I've tried to disassemble it but the cylinder thingy is frozen. It seems to be frozen in the locked position, even though I've used both the key and the thumb lock to try and unlock it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
lauraevalentine , If this lock set is still installed on door, through the key slot, liberally squirt penetrating oil/ WD40 with a small injecting straw/nozzle and insert key in and out/wiggling and repeat several times till lock set works. Below find links for door knob removal and link from kwikset trouble shooting etc. Good luck.
https://www.youtube.com/watch?v=vESDjMTc...
https://www.youtube.com/watch?v=eigYEYR0...
http://www.kwikset.com/customer-support/...
Punteggio 3
Aggiungi la tua risposta
lauraevalentine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,217
