how to i get my wireless to work
how to create a wireless connection
Questa è una buona domanda?
Do you have any other devices which are connecting to your WiFi network? Are they working at the same physical location you are trying to setup this computer?
Look at the settings of one of the working systems to see what you need to set on system that can't connect.
The wireless Bridge or wireless Router (called an Access Point {AP} for either) may also require a given type of 802.11 service (A, B, G or N) or a given band in the case of 802.11n (2.4 or 5.0GHz) for your systems to connect to it. Make sure your system can access the AP's service type settings.
Some older MacBook Pro's can't access 802.11n networks without a firmware upgrade, or access the 2.4 or 5.0GHz bands
How to tell if 802.11n-enabling software is installed:
If u have a wireless network that you might want to connect to,you reqire the SSID of the network from the network creator,otherwise your wireless wont work.
You can always check the wireless network strength.If it is too low then you wont be able to connect to the Internet.
All the above mentioned solutions are with respect to software alone.You might also want to check if there is any hardware fault with your wireless router or NIC.
Network - verify that your Airport card enabled.(turned on) If it's detecting a network (curved arches). If it is then the problem is with your router, check their directions or support pages.
Use Mac Help from Under Help in the Menu:
* Network, share, and go online
* Setting up or joining a network
If this answer is acceptable please remember to return and mark it.
Good Luck,
N.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,289
1 Commento
Please be more specific with your question. Do you have router problems, or is the computer not working as it should?
da QEII Student IT
