Salta al contenuto principale
Manuali di riparazione e supporto per veicoli a quattro ruote da passeggeri e da carico.
11828 Domande Visualizza tutte
How do I fix error code P1172 in 2005 Verona Suzuki?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@mike_mac , Mike, Suzuki error code P1172 - Lambda controller limit malfunction bank 1 too lean. Info found at link #1 below.
Possible faults are, low fuel level, low fuel pressure, restricted fuel system(plugged filter/pinched/damaged line , MAF(mass air flow)/MAP(manifold absolute pressure) sensor faulty/malfunction, also check for vacuum leaks as link #2 Suzuki trouble shooting forum recommends.
Make sure fuel level is good(not empty), check for clogged gas filter(replace if it has not been done recently) and pinched/damaged fuel line, have fuel pressure checked(replace fuel pump if found to be too low) and or clean/replace MAF sensor. Good luck.
http://www.autocodes.com/p1172_suzuki.ht...
http://www.suzuki-forums.com/suzuki-vero...
Punteggio 2
Aggiungi la tua risposta
MikeMac sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 183
