Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
White screen on iMac 2011 27"
Hello everyone.
I have a big problem.
First of all, i know there are many of these threads about this problem, but i not manage to find a solution for me.
I have a iMac 27" mid 2011. Everything works fine, until i tried to install Bootcamp.
The installation went fine, and i could boot in Windows.
There was some Windows updates i will install, and Windows ask for reboot.
After that reboot, my iMac comes with only a white screen. and nothing else. And altso the chord sound.
I trid reset PRAM, and, COMMAND+S, D, Command+SHIFT+R+P and so on.
Nothing workes.
Is anyone have an idea?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
A white screen usually indicated a problem relating to the hard drive. Try starting up holding down the option key and see if you can get to the repair partition. If so, run Disk Utilities.
Punteggio 3
3 Commenti:
I tried that. But it's not working. I worked with this for a long time, and an hour ago i decided to take out the HDD. Unfortinately one of the pins on the display ribbon broke, so i ordered a new one now. I will update later on the week, when i tried a new harddrive.
da
How did it go?
da
Sorry my late answer on this topic. As meyer said it was hard drive related. I took out the hard drive and formatted it from another computer. Then I put the hard drive back in and after that I could start my iMac again and install macOS from start
da
How to do it with another KEYBOARD WIRELESS. I am with a customer iMac 27. How to make my keyboard work?
Punteggio 0
Aggiungi la tua risposta
jonasbak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,333
