Salta al contenuto principale
A larger version of the P-series. Repair will require screwdrivers and some tool for prying areas open. Comes in Red and Black versions.
rotary multiselector does not work
This part of the camera does not work properly
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@ljalvarez ,Luis, Mode dial problems, If camera still under warranty and for info. on your issue you may want to contact Nikon at the link below. Also find your manual pdf. below for trouble shooting and setup instruction. If manual sheds no light on your problem and out of warranty take camera into a good camera repair shop for a diagnoses and estimate on repair. Good luck.
http://www.nikonusa.com/en/service-and-s...
http://cdn-10.nikon-cdn.com/pdf/manuals/...
Punteggio 2
Aggiungi la tua risposta
Luis Alvarez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 447
