Salta al contenuto principale
The Sprout Channel Cubby™ was first produced in 2014, it is a child friendly device that provides the functionality of a tablet. It boasts a 1024x600 touch screen, Two 2 megapixel cameras (one rear facing and one front facing), Parental controls and security, HDMI connectivity, Bluetooth, WiFi, 16GB Memory, 1GB RAM, and a 1.2 Ghz processor. It has access to internet and various application stores and applications, which can be limited by the parental controls
sprout channel cubby with broken screen
it turn white with black and wont turn back normal
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
danielgaming99999, Go to the 1st link below sprout channel cubby support and use the instructions to reset/restore your device. If that does not help, chances are you will need new/replacement digitizer/screen for your sprout channel cubby. 2nd is a guide to show how to replace the digitizer/screen and the 3rd link shows replacement part, which you can also google search for better pricing. Good luck.
http://sproutchannelcubby.com/tech-suppo...
Sprout Channel Cubby Digitizer Replacement
https://www.amazon.com/Replacement-Displ...
Punteggio 2
Aggiungi la tua risposta
danielgaming99999 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 735
