Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
I think I broke everything.
I tried a repair on this laptop made by the devil. Broke multiple things on logic board. Fan, Trackpad, and one of the connectors to the wireless card. Is there anywhere I can send this so I can just tap out? I don't know if its even worth fixing at this point.
Questa è una buona domanda?
Punteggio 0
2 Commenti
I broke the charging port off the circut bord. The wire that connects the fan to the logic board is broken. Multiple track pad wires are broken. one of the three pins that connects to the wireless card is broken.
da
@mayer may know someone....
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Sounds like repair may not be your forte.
Well I've only been repairing them since 1979. Yours may not have been made by the devil but it sounds like it certainly been worked on by something akin to one. As a pastor as well as a Mac repairman I can perform an exorcism on it, attempt to purge it from the curses that almost certainly have been heaped upon it. For those services, I do not charge. But for replacing the logic board, I do charge, Apple most likely will not touch it except for a price close to the cost of the whole thing. I usually do not solicit business on this site and this is really not a solicitation but an offer for a solution. Click on my icon and email me. Tell me the truth about why you were even in it in the first place and what else was damaged. I'm 97% sure I can get it working for you at a price better than you will find elsewhere. It sounds like you will need a real expert to resurrect it.
Punteggio 2
1 Commento:
You make me wish I had a repair business.
da
If you want the old motherboard repaired, send it to @jessabethany at iPad rehab. It would probibly be easier to replace it, but more expensive.
Punteggio 0
1 Commento:
She really doesn't do Macs. She does phones and pads.
da
You can always ship it to Apple! Schedule an appointment at your local Genius Bar and see what your options are.
Punteggio -1
1 Commento:
@entendu they won't fix it, they will tell you to get a new logic board.
da
Aggiungi la tua risposta
Brad Morgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 160
