Salta al contenuto principale
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
Time Capsule reset not working
Here is the challenge:
Airport Utility cannot see the base station from any computer, phone nor iPad. I suspect wireless connectivity is not working either (hard to tell because I have several base stations creating my network). To make matters more confusing, I have a computer plugged into the TC. That computer cannot see the TC in Airport Utility, but uses the TC for a wired internet connection that continues to work. I have powered the TC off and back on again, done a soft and a hard reset all to no avail. All LEDs remain green, but I still cannot backup, still cannot use the drive and still cannot see the TC in Airport Utility. What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I suggest that you start by performing a "factory default" reset on the problematic TC.
You may have to do this a few times to get it to "stick." Once done successfully, the TC will be back to its "out-of-the-box" configuration as a wireless Internet router broadcasting an unsecured Wi-Fi network with a network name of something like: Apple Network NNNNNN
A Mac should now "see" the TC in the OS X/macOS Wi-Fi icon drop-down menu under new base station. Select it and the AirPort Utility should fire up so that you can make any necessary changes to meet your networking goals with the base station.
Punteggio 0
Aggiungi la tua risposta
stephen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,072
