Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Logic board repair or soldering?
Hello everyone. I have changed my logic board in my 5s and my old one had bent connectors on the logic board so the home button/power etc cable won't connect.
How can I fix this? Can I solder it onto the bent pieces?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Send it to @jessabethany at iPad rehab, she can fix everything.
da
@gigabit87898 change your personal preference in your answer to a more objective one. Not sure how many boards you have send of to get fixed, but your answer only describes one source and there are plenty others. You are also needing to know the location. for example when in Canada, send it to @refectio etc. How about Australia (got some good people down there as well)... I am sure you get what I mean.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
No the connectors have to be replaced entirely.
Punteggio 5
U need a microscope.
U can repair or change it if you have the right tools and a good experience with microsoldering. This is not easy work, they actually need great patience and skill. If you wanted to learn something better start to repair now and if not you better send it to micro solderer like @jessabethany or somebody else near u.
Punteggio 0
It is much cheaper to buy a second hand logic board for the 5S instead a repair. Here in the Netherlands you can buy these for arround €50,-
Punteggio 0
Aggiungi la tua risposta
Benito Graffagnino sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 161
