Salta al contenuto principale
Released in 2011 - Core i3-2330M processor
How do I fix my number keys
i've had numerous problems with my Dell laptop, the number keys are not working right. For example, I cannot type the number five at all it becomes a seven. I will type them in order from one to zero to show you what happens...
123T4T4Y7Y7]89[0 the number two also turns the caps light on and the number nine turns on the F seven key.
I've also had issues with the entire computer shutting down when I am working on it, it turns completely off and now its started flashing while I am using it too.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
  • Restart your computer if you haven't already.
  • Try an external USB keyboard if you have one to see if there is any problem with that.
  • Open Device Manager and update the keyboard driver(s),
  • or go to dell.com support and put in your Service Tag to get a list of drivers (or use the automated tool on the Dell site to scan your computer and suggest driver updates) and update from there.
  • If the keyboard still isn't working at that point, see if you can get into the BIOS diagnostics and test the keyboard there.
Punteggio 0
Aggiungi la tua risposta
michelealoia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 136
