Salta al contenuto principale
Questo è un controller basato su touch-screen associato con la console videogiochi Wii U. Fu rilasciata nel 18 novembre del 2012 ed è disponibile nei colori bianco o nero. Numero del modello: WUP-010(EUR/USA/JPN)
83 Domande Visualizza tutte
Gamepad is completely dead
Hi. My Wii U gamedpad is completely dead. I have tried to take out the battery for a few hours and tried to start it without result. The battery has power when I loaded it on the side and measured the voltage in it. Now I screwed apart the gamepad, but nothing is loose and I can not see that any circuit has burned. Is there a fuse in the gamepad that could have tripped? Where? I suspect otherwise there is a circuit board that has given up but which when the gamepad is completely dead? I do not want to spend money on a new one when I plan to buy nintendo switch later next year. Hope you can help me to solve the problem. Sincerely, Raoul
Questa è una buona domanda?
Punteggio 0
1 Commento:
Thanks for the reply. My gamepad is completely dead, no lights or any lights. How do you mean wifi / bluetooth? Do you now where i can buy parts? the shipping is so expensive from ebay to Scandinavia. :)
da
Aggiungi un commento
3 Risposte
Hi Raoul,
I am in a similar situation with a Gamepad, however in my case is quite different.
I replaced the LCD and touch screen and getting response from the touch screen and sounds.
In my case seems to be video related issues, in your case I recommend you to verify the wifi/bluetooth cards.
If any of those are not properly seated or damaged the remote will not power on.
Regards,
JM
Good luck and good repair.
Punteggio 0
More likely than not you're looking at a bad motherboard. If you press the Home button and the power button at the same time does the blue light turn on and then fade away shortly after?
Punteggio 0
I got nothing. No light.
Punteggio 0
Aggiungi la tua risposta
Raoul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,061
