Salta al contenuto principale
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
Questa è una buona domanda?
Punteggio 2
6 Commenti
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
da
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
da
cant get it to work either way.what to do ?
da
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
da
I've got it working, see my answer below.
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
Punteggio 0
1 Commento:
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
da
Risposta Più Utile
On your RCA tablet go to settings, click on display and then configure HDMI settings.
Punteggio 1
1 Commento:
What do you do after or even how do you configure HDMI settings
da
Aggiungi la tua risposta
boogityboo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 13,203
