Salta al contenuto principale
I piumini ti avvolgono in un morbido calore, isolandoti dal gelo e dal vento. Sono altamente comprimibili, estremamente leggeri per il calore che offrono e ultra confortevoli per l'uso quotidiano.
40 Domande Visualizza tutte
My Patagonia coat leaks down.
My Patagonia coat leaks down. I turned in one in hopes the new one wouldn't leak, but it does. I can't wear it with anything black or navy or charcoal. Very disappointed. Was told to run it through the driver many times--that didn't work.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you washed you coat at all in detergent or bleach or used fabric softeners you will have destroyed the protective waterproof coating . You may find this artical helpful
https://skyaboveus.com/misc/How-to-water...
Hope this helps
Punteggio 3
1 Commento:
I did not wash it at all. I seldom wear it because of the leaking. It has leaked down since day one. My first one did, as well. But my down 'sweater' does not.
da
Aggiungi la tua risposta
Marcia Lorenzen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 577
