Salta al contenuto principale
Phone stuck in a boot loop
The other night my phone did an update and when I woke up the next day it was on the Huawei logo that appears when booting the phone up, I took out the battery after 10 minutes of it staying on the logo and turned it back on and the same thing happened again, I have entered recovery mode and done a factory reset and wiped the cache partition, I cannot find a download for the right firmware. Any help would be greatly appreciated
Questa è una buona domanda?
Punteggio 2
1 Commento:
Same here mines stuck on logo screen will not turn on tried everything
da
Aggiungi un commento
2 Risposte
Use a small paper clip in and in the back of the tab is a small button by the headphone jack and quickly click it with the paper clip then turn it back on
Punteggio 0
1 Commento:
Thank you, I found the hole and placed a paper clip in it and pushed but it didn't click or move at all, If you have any other tips they would be much appreciated
da
follow instruction here
Punteggio 0
Aggiungi la tua risposta
andrews122 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 10,817
