Salta al contenuto principale
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
225 Domande Visualizza tutte
iPod is frozen on hold.
My iPod Photo is stuck on hold. I cannot reboot. I also tried installing a hold switch from another iPod Photo & that didn't work, so it isn't a bad switch. Any ideas? New hard drive? New logic board? Something else?
Questa è una buona domanda?
Punteggio 2
1 Commento
@zookie does it show the lock symbol at all? does it change as you move the slider?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I got the problem solved with the help of a contributor to ifixit & am posting the solution here in case it helps anyone else. In my case the ribbon wire going from the switch to the logic board had somehow become a bit loose & wasn't securely fastened. The ribbon feeds into a small square in the upper right corner of the logic board. I simply pushed down on the square & heard a click. Problem solved. Ifixit has some great photos of the iPod insides that show the components I am referring to.
Punteggio 2
If this is a 4th generation honestly I'd probably lean towards replacing the device with another 4th or even 5th gen model. Not typically a cost effective repair.
Punteggio 0
1 Commento:
Thanks Matt. I actually got an iPod Touch recently, but the 4th gen photo is my favorite model. It actually does some things the Touch doesn't & almost everything is easier to do on than on the Touch. The click wheel is genius.
da
Aggiungi la tua risposta
Les Girouard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 210
