Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Replacement screen popping up
I received the replacement screen plus digitizer full assembly for the iphone 6, white and the screen is not flush against the frame of the phone. The phone frame showed 2 impact points and I shaved them down with a razor blade. The screen still jutts out a bit. I then compared the replacement with the original and there seems to be a difference. My client is upset. What do I do to correct this quickly without having to return the part and waiting another few days?
Questa è una buona domanda?
Punteggio 1
1 Commento
Where did you buy the screen?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Unfortunately there isn't much you can do with that part, as it sounds like a cheap part.
Cheap iPhone 6 screens have thicker frames, too thick or too thin glass, and they tend to use hot melt glue on the frames, so the glass can come away from the frame pretty easily.
Try a different supplier with better quality parts. :-)
Punteggio 1
I received the part from iFixit. Trying to avoid having to return the part while leaving the client with a defective phone. Wondering if IFixit will send me a replacement part as a swap and send the one they sent back. It was listed as an "A"quality part too.
Punteggio 0
Aggiungi la tua risposta
lhernan3 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 714
