Why will my Onda VI10 not power on?
My tablet will not power on. I have tried a different charger but, it still shows no signs of making an effort to turn on!
Questa è una buona domanda?
Faulty power adapter
Check to make sure the outlets is working, plug in the adapter, if tablet still do not power on then you might consider replacing the charging adapter.
Faulty power button
Carefully remove the four screws that hold the back casing and check to make sure
your power button is not sticking or is not making contact with the powering switch that is connected to the circuit board.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 220
iFixit Technical Writing Project
da L Pfaff
