Salta al contenuto principale
Annunciato il 9 settembre 2014, questo dispositivo rappresenta la prima incursione di Apple nel mondo dell'elettronica indossabile. I manuali di riparazione iFixit sono applicabili all'Apple Watch (acciaio) e Apple Watch Sport (alluminio).
Use a display from the original Apple Watch for the Series 1?
Hey everyone.
I have recently broke my series 1 Apple Watch, and I am now looking for replacement Display-units. The device does still display things, just the glass is broken. I have found several ones, allthough they are all rather expensive. I just stumbled upon an auction for an original Apple Watch Display, which comes from the series 0 model. As its current price is relatively low, I'd like to bid as well.
I was wondering though: Is it possible to use the Display unit from an Apple Watch Series 0 for a Series 1? I does seem to have the same connectors, and I don't remember Apple mentioning any change of the Display when they issued the Series 1 Watch.
I would be really thankful for an answer to this problem, or at least some opinions.
Many thanks!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The display for the original Apple Watch and the series 1 can be interchanged as the only thing changed really was the processor speed. Ive also just doubled checked on here and both have the same screen/digitizer, Item Code: IF308-009
Hope this helps
Punteggio 1
4 Commenti:
Many thanks for your reply, I really couldn't find a way of figuring this out. I didn't know one could search for parts on here, but now I do.
Also by the way, do you know what the little cable on the back of a Watch display with the three small solder points does?
Thanks alot in advance
da
The cable on the back with the 3 small solder points connects the power supply to the proximity sensor.
da
Wow, I did not know this. I am going to order a completely new display unit anyway, but is it possible to desolder that cable without damaging it? Just something I want to try.
da
Yes it's possible to remove to cable without damaging it. Just apply a little heat to each point while slightly lifting the cable and it will come straight off (no need to apply any additional solder)
da
Aggiungi la tua risposta
Daniel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 404
