stuck on apple logo
Hi guys
my iphone 5s stuck on apple logo after it dropped on the floor.
i tried to recover it by using home and power keys at same time. but the problem is exist.
Questa è una buona domanda?
Hi guys
The physical drop clearly damaged something inside your phone.
You may be lucky; it could simply be a flex cable that partially unseated from its connector due to the impact. If you feel confident, open your phone (you will need a special screwdriver) and follow the directions for the 5S display assembly replacement guide.
Sostituzione schermo iPhone 5s
Be very gentle as the flexes and connectors are delicate. Re-seat everything and try the phone again. If it doesn't solve your problem, you may have some logic board damage that will need to be looked at by a qualified repair shop that does micro-soldering.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 124
