Salta al contenuto principale
L'eMac era un Mac tutto-in-uno basato su G4, progettato per il mercato dell’educazione e rilasciato nell'aprile 2002. Fu l'ultimo Mac a utilizzare un display CRT ed era venduto a un prezzo basso a scuole e altre istituzioni.
eMac won't boot either
Emac will not boot after last software update. Will not boot from hard drive or disk. Three things happen. First, I get a kernal panic and freeze after a few seconds, or the computer shuts down. or the spining indicator goes on indefinitely. On rare occasions, I get the symbol for OS not found. I have reset the PRAM and I get both bongs. Any ideas?
Questa è una buona domanda?
Punteggio -1
1 Commento
Thanks for suggestions, but nothing worked to boot the machine. I do not know if we are facing a bad hard disk or mother board. If it was a hard disk, I assume I should have been able to boot from the install disk. So I fear it's a mother board. Until next time....Adios
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Boot from your system installation disk by inserting the disk and starting up holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk utility and repir the hard drive till it runs clear. Then try restarting.
Punteggio 2
1 Commento:
agreed +
da
Sounds like one of the updates failed. If you still have the install disks, you can reinstall the operating system and select the option to save all of the old files in a folder called "Previous System" If you want to keep them, and have inportant info that you want to keep. Short of that, there is no way to really fix this.
Punteggio 1
Aggiungi la tua risposta
professor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,262
