Car will not start throwing 0335 0340 codes and have replaced already
Ok I replaced the crank and cam shaft sensors n this car it's only codes it's throwing ran before I parked it to replace the sensors and now it won't
Questa è una buona domanda?
@cbrin , Chris, are you still getting both P0335 and P0340 codes after changing both, did your erase the codes after work done? Did you install the crank sensor properly so it could be read properly(not backwards) and wires are back in position so belt can not damage. Rescan for trouble codes and I will try to get back to you. Add any more info. you can to aid in diagnosing year, engine, auto/manual trans, does it start or just cranks, other or recent work performed. Good luck.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 114
