Salta al contenuto principale
Released March 2011. Identified by model number SDVD9004.
Why is my disk not reading?
I place my disk in the DVD player but the screen says "cannot read." What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi! Sarah
Check if the disk is clean and scratch-free (you can clean with alcohol), maybe you use Bluray disk and your DVD Player can't play Bluaray disk. If is external DVD Player check if the cable are good or you USB port it good too, try another USB port. Good Luck!!!
Punteggio 1
How to fix portable DVD has stopped dynamo and error disc
Punteggio 0
Aggiungi la tua risposta
Sarah Henry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 528
