Salta al contenuto principale
Released August, 2010. Identified by part number: 884354009250.
I need some Button Turn off/on
Questa è una buona domanda?
Punteggio 5
2 Commenti:
I have the same problem, the button fell out. I have the button but there seems to be something else that is missing because the button doesn't work. when placed back, it's loose. Did you fix it?
da
I also have this problem. Anyone?
da
Aggiungi un commento
1 Risposta
Sometimes my H1 loses the date and time. When it does that, it will not record. The unit turns on but pushing the record button does nothing.
I turn it off, hold down the Record button while powering the unit back on. It then defaults to the date. Use the forward or backword buttons to get to the correct date or time. Use the Play button to set the time after you choose the correct time.
Every time I reset the date and time it makes the Record button work. Try it and answer back.
Punteggio 0
Aggiungi la tua risposta
Cio Fadhilah sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 39
Tutti i Tempi: 1,339
