Need a diagram of 91 chevy c1500 steering column
Steering wheel is very loose . Took it apart and tightened it up and put back . Wll not go back together. Would like a diagram of steering column.
Questa è una buona domanda?
kpgklm, The links below will show exploded view and vids on steering column to aide in your repair. Check the attached links,instruction and guides, Good luck.
http://www.steeringcolumnservices.com/ex...
L Pfaff came thru with flying colors.. Very fast response with the info I needed. Thank you so much ! Still good people around !
kpgklm, thanks for the response, if it was the answer you needed vote it up, Thanks.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 55
Tutti i Tempi: 15,483
1 Commento
Make sure bearing is assembled properly just behind steering wheel
da p_buchwald
