Salta al contenuto principale
The Canon PowerShot SX160 IS is a 16.0 megapixel digital camera with a 16x wide-angle optical image zoom and a 3.0 inch LCD.
20 Domande Visualizza tutte
Why does the lens not retract
the lens will not retract.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
newmangeneva60, 1st install good fresh batteries and try. If still not working, there is probably dust/dirt/grime on the barrel of lens or mechanism, jamming it from retracting. Look around the lens barrel where it retracts back into camera, if you visually see debri try clean it out carefully with a small needle, finish cleaning with compressed air or vacuum to dislodge dust etc. and try camera.Check the attached link for more trouble shooting and instruction. Good luck.
http://camerarepair.blogspot.ca/2007/12/...
Punteggio 1
Aggiungi la tua risposta
newmangeneva60 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 555
