Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
No clear picture after digitizer/glass screen replacement
After replacing a broken screen/digitizer the iPad does not have a clear picture. It's only a light green color with some vertical lines. I can't even type in the passcode cause I can't see it, it's only a light green color. When the iPad got dropped and screen cracked it still worked fine, able to play games and music. But after replacing the digitizer it doesn't. It still lights up just no clear picture or anything. Do I need to replace the LCD now? Wondering if that got damaged in the digitizer replacement.
Questa è una buona domanda?
Punteggio 0
2 Commenti
I'm not sure how to upload a picture of it. There isn't an option to do that on here I don't think. Do you know how?
da
[image|950251]
Hope this works! Trying to post the picture.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sounds like LCD damage, so you would need a new LCD. Are you able to upload a picture of the issue so we can double check?
Punteggio 2
Trying to post picture.
Punteggio 0
1 Commento:
Yes that looks like LCD damage. Replace the LCD
da
Aggiungi la tua risposta
Emily Peers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 76
