Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
replacement battery contact is different
I've tried two replacement batteries. The batteries fit and screws in ok, but, the contacts on both [including an ifixit] replacements are slightly different and don't make contact.
Questa è una buona domanda?
Punteggio 0
1 Commento
the Iphone 4s CDMA battery is the same as that of the iPhone 4.
4s CDMA batter is different from the Normal 4s... so you can use the Iphone 4 battery for Iphone 4s CDMA..
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
there is a iphone 4 , iphone 4 (CDMA) and iphone 4S. the iphone 4/4(cdma) have the same battery and the iphone 4s has its own battery. make sure you have the right battery for the device you are working on.
Punteggio 1
2 Commenti:
The model number on the back of the phone corresponds to 4s and the ifixit replacement says 4s. But, I might try looking at a 4 battery and seeing if the contact is what I need.
Thanks for the response. It might put me on track.
da
glad too help. let us know if you get it working.
da
Aggiungi la tua risposta
John Dee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 52
