Salta al contenuto principale
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
70 Domande Visualizza tutte
fan turns fast and after that lcd gets dim
hi.
after a week this laptop came back and now i findout thats fan works hard temporally and loud after that lcd brightness play up down and get dim.
i used core temp app and hardware tester but no error showed up.after using them and put the cpu and ram and video under persur this not happening soon to soon.
its plugged in without battery may it can do that?
i think maybe heatsink not workd good like past.
its coming back with fn+f8 only.
tell me what you think?
thank you for your f1!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Check the cpu/gpu cooler that is assembled correctly and clean it and change the thermal paste to see if you can get better results that seems that the cooler is not attached well...
Punteggio 0
Aggiungi la tua risposta
Emin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 44
