Salta al contenuto principale
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Domande Visualizza tutte
Adhesive Strips Replacement - Removing old adhesive issue
I installed an SSD on this model about a month ago. The top right corner of the screen started to pull away from the adhesive for some reason so I am redoing the adhesive strips but I'm having a hard time getting all of the adhesive residue off this time. Do the strips 'need' to be put on completely clean plastic/glass to work effectively or is it ok if some glue residue is left on?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I like to completely clean them with no reside. Use some Goo-Gone on a paper towel to get the tough stuff off.
Goo Gone Pro-Power Goo & Adhesive Remover, 8 oz
Punteggio 3
1 Commento:
I usually use goo gone for sticky stuff, but wasn't sure if that would be ok on a computer. Thanks!
da
Aggiungi la tua risposta
scentaur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 333
