Why will the A button not work when I press it?
I press the A button in a game that uses it and it will not work. How can I fix this?
Questa è una buona domanda?
The button was dirty underneath so I removed it, cleaned it with rubbing alcohol and repaired it.
The A button may not work because the connection from the A button to the motherboard may be interrupted. I suggest you check out our button replacement guide.
It's possible that there is something lodged beneath the button that is causing these problems. Opening up the controller and cleaning beneath the problematic button may solve this issue.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 139
da Andrew Gonsalves
