Salta al contenuto principale
The G3 Controller is gamestop's version of a gamecube controller, equipped with A, X, Y, Z, B, Turbo Button, joystick, C-stick, left and right triggers, and a directional pad.
Why is my controller moving the character when I am not
My controller causes my character to move when I do not move the control stick. Is it dirty or is it just a bad signal?
Questa è una buona domanda?
Punteggio 2
1 Commento
Turns out there was an error when the console recognized the controller so I just unplugged it and re-connected it to the console.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Often times, disconnecting the controller and blowing into the connection port on both the controller and console can fix this problem.
Punteggio 1
Punteggio 0
It may be dirty or your joystick may be misaligned. I recommend you check out our joystick replacement guide, and use the steps to clean out the area and then reattach your joystick. If the problem still persists it may be a problem with your motherboard.
Punteggio 0
Aggiungi la tua risposta
Andrew Gonsalves sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 514
