Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Weird deformed letters in the text
Hi,
I attached some printscreens.. Does anyone has experience with this issue? It looks like there is a problem with text or image rendering, best visible in Safari, but also happens in other apps.
I tried full restore to latest version without solution, no waterdamage, device looks fine.
Thanks in advance.
Grts, Gauthier
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Has the screen been repaired before?
easy way to tell without opening the device is look for a blue tint in the front camera lens.
Punteggio 0
1 Commento:
Thank you for your response.
It was replaced before. I assembled a full original screen again, without solution.
Do you think this damaged the logic board?
da
Aggiungi la tua risposta
Gauthier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 143
