Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
597 Domande Visualizza tutte
Keyboard backlight led replace
Hi all
I got mine friends machine today to repair. I replaced the battery of the laptop. But I also saw that the backlight of the keyboard isn't working well. One of the leds is not working. I tested the other leds with 3v and they are working. The led that is not working, is burnt out. I see a yellow stripe on it.
Is it possible to desolder the faulty one and replace it with a new smd led?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes it is possible if you can get the correct LEDs and solder these on, might be best to remove a working one from another used backlight, if you have any. You may need to clean the middle sheet of the backlight as well, so it evenly distributes the light.The whole part cost 6$ though, so in my opinion it would be quicker and easier to replace the whole backlight.
Punteggio 1
Aggiungi la tua risposta
Uas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 401
