Salta al contenuto principale
Flywheel removal to replace sheer key
I need to remove the flywheel on a Briggs and Stratton 5 hp engine to replace the sheer key. I have done this before, but I can't remember if the threads on the shaft are right hand or left hand. I have removed the cover and part of the pull cord start assembly. The body keeps the flywheel on and I have not been able to un screw it!
The engine is back firing through the carberator that I'd how I know it has jumped time.
Questa è una buona domanda?
Punteggio 0
1 Commento
Thank you! When the righty did not work, too tight I guess, I thought it was time to check with someone else. I will bear down this time!
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
smithron4 just checked on one of mine. "righty tighty lefty loosy" So CCW to loosen the nut should work
Punteggio 2
Aggiungi la tua risposta
smithron4 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 294
