Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Domande Visualizza tutte
Autumn cleaning disaster iMac mid 2010
Hi guys
I just cleaned my mid 2010 iMac for a first time.
took it all apart cleaned all the parts changed paste on GPU CPU.
And now i have a problems.....
1.Bluetooth doesn't seems to work ( can't connect my wireless keyboard and head phones)
2. in Stat panel I only see CPU Heatsink ( should there be a CPU doe temp??)
3. ODD and CPU fans running full speed ( can not longer control them with FanControl)
On the bright side temps dropped by 10 deg. :D
What would be your "protocol" to undo this disaster ??
Did i connect some sensors plugs inccorectlly ? or it is something more serious?
I would appreciate any help as I am and IT idiot
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Reconnected bluetooth card, reconnected ambient temp sensor unit seems to work fine now . Big thx to Mayer for help
Punteggio 0
Risposta Più Utile
What did you do on the hard drive? Was it changed? Check to see if the temperature sensor is fully seated into the logic board. (Either will cause run away fan issues.
Did you remove the battery or replace it?
Punteggio 3
8 Commenti:
I didn't touch SSD just disconnected from logic. I haven't touched battery. Stranglly after cleaning Mac is running noticeably slower ( lower fps in games) ??
But again Mac is running 10 C cooler with the same settings.
da
Of course it is running cooler the fans are at full speed. Check to see that the sensors are correctly and fully plugged in.
da
they were on full speed before cleaning
da
This machine did not have an SSD. It had a hard drive. Have you changed it?
da
yes but it was done 2 years ago
da
Mostra altri 3 commenti
Aggiungi la tua risposta
dominiku sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 140
