Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
speaker and voice recorder is grayed (not active)
hi somebody bring me i phone with broken LCD after changed
i see when make calls speaker icon is grayed (not active) even sound recorder too i cant record any thing its not active to press it what to do ???
Questa è una buona domanda?
Punteggio 0
1 Commento:
thanks for reply the loud speaker became grayed when call
and when try use siri and hey siri its passed without specking u can say its finished test sound without say hey siri
i tried to disconnect the flex of (front camera and light sensor and ear sound )same
even i tried to disconnect the charge base flex cable same
i make restore with i tunes with final ios same same
da
Aggiungi un commento
1 Risposta
So you're saying that you can only use loud speaker and not the earphone speaker at the top? The iPhone 6 has 3 different microphones, one on the bottom, one next to the camera on the screen and one next to the back camera.. I know siri uses the front mic. Try using siri and see if it understands you, also try taking a front facing video and see if you can hear anything back in the video.. If not then it sounds like whoever replaced the screen didn't install the front camera, prox sensor and mic flex cable or it may be damaged which would explain why sound recorder wouldn't work. It may also just be a software issue. Have you tried restoring it with iTunes?
Punteggio 0
Aggiungi la tua risposta
alialjoranyy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,051
