Salta al contenuto principale
The Microsoft Surface 2 was manufactured by Microsoft Corporation and is the second generation of Microsoft tablets. It was launched on October 22, 2013 and includes features such as upgraded processing power and screen resolution.
Change Battery Microsoft Surface 2
How do I replace the Microsoft Surface 2 battery?
What material should I use to assemble the screen with the back cover?
Questa è una buona domanda?
Punteggio 2
3 Commenti
I must disconnect the display from the rear panel with a heat gun, then to reassembly the Surface, I will have to use glue to assemble the tablet?
da
What should I use to connect the ribbon cable to the motherboard?
da
How do I remove the battery after removing the motherboard?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@piero90, Piero, remove the old glue/tape with a (little) heat and a plastic scrapper/credit card/fingernail, then use some 90% isopropyl alcohol and a lint-free cloth to clean the remaining adhesive. Use a good quality thin 2 sided tape to put back together, which you can find doing a google search/hobby shop/small electronics repair store when you figure which width would work for you. Links below show tear down of the Surface 2 and adhesive strips being applied. Check the attached links,instruction and guides, Good luck.
http://www.techrepublic.com/pictures/cra...
https://www.youtube.com/watch?v=Man6w3sd...
Punteggio 4
22 Commenti:
How I remove the ribbon cable in the Microsoft Surface 2?
da
@piero90 , Piero, at 27.00 min's in on video shows ribbon cable removal and the 2nd link here shows more detail of the cables removal, good luck with your device.
Microsoft Surface 2 Screen Replacement
da
Then I have change the battery, I must to use glue or thermal past to reassemble the tablet?
da
@piero90 , Piero, it would probably be best to reapply the thermal paste if removed and glue to a like factory install to prevent possible problems. Have a good day.
da
So I must to use the glue and the thermal paste together?
da
Mostra altri 17 commenti
Aggiungi la tua risposta
Piero Sabino sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,455
