Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
Can the SSD be switched out?
Can the SSD be switched out and upgraded ?
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
7 Risposte
Risposta Più Utile
Looks like the entry level 13" isn't soldered
OWC noted the following points in its teardown.
– Bottom was more difficult to remove than previous generations, but it was not glued.
– Speaker module needs to be removed to pull SSD back.
– SSD had very strong tape covering the interface port.
– Laptop automatically turns on when you open it regardless of pressing power button.
Punteggio 2
2 Commenti:
If you review the OWC vid you'll also see the SSD module is very different from the older systems and it looks like a custom part! So, even if its removable, it will be a while before we see a 3rd party option.
da
@danj Yes I saw that! Hopefully the wait isn't as long as it was for the Retina models!
da
http://blog.macsales.com/38440-ssd-in-la...
Punteggio 1
Yes, Please look at
Punteggio 1
Yes. But so far no one has made an SSD that is compatible with this model, the first few will begin to pop-up within the next few months.
Punteggio 1
Yes is it removable.
Update (10/31/2016)
Punteggio 0
2 Commenti:
Do you have a back up link on this?
da
I would like to know where you got this information. Nothing on the internet says Soldered, but I wouldn't put it past them
da
Anyone here who knows the pinout of the new SSD?
Punteggio 0
Adapter for MacBook Pro 13” 2016/2017 nTB
https://www.globalmac.cl/Adaptador-SSD-M...
(Chile)
Punteggio 0
Aggiungi la tua risposta
benkuza sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 8,129
