Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
Replace SSD with models from 2015.
Hi
Can I replace original M.2 SSD with something like SSD 960 EVO NVMe M.2 1TB ?
Will it work at all? And can it support the speed of storage?
original is 500 MB/s write and reed, and on link is 1900 write and 3200 read MB/s.
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sadly, no.
Apple uses a different physical interface from the M.2 SSD products you can buy from Samsung. While many of the SSD's Apple uses are made by Samsung they are OEM.
There is a 3rd party that does make a compatible SSD OWC - SSD Upgrades for MacBook Pro with Retina Display 13" & 15" Late 2013, 2014, & 2015. Or, you'll need to find a used unit on eBay which can be a bit of a gamble.
Punteggio 2
Yes you can with this adapter: http://eshop.sintech.cn/ngff-m2-pcie-ssd...
but only Linux or Windows installer will detect the drive. MacOS doesn't support NVMe for OS booting at the moment.. maybe in future.
Punteggio 1
2 Commenti:
So apparently the MacOS High Sierra will support nvme ssd out of the box. :)
www.insanelymac.com/forum/topic/324306-nvme-native-support-in-1013/
da
Good find!
mmm... I'll need to check it out once I get the needed parts. Remember High Sierra is in Beta so we'll need to wait till the full release to be sure they don't close the door on us ;-}
da
Aggiungi la tua risposta
Volodymyr B sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 324
