Salta al contenuto principale
Released November 12, 2012; Device ID436WTA; 4.3" Tablet
How do I change the battery of the device?
When I opened the device, I see that the battery is welded. How can I take it apart and replacing it without damaging the device?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Yes, unfortunately the battery in this device is soldered in place. To replace the battery gently tug on the old batteries soldered connection to break the wires free, making sure not to pull the wires out of the motherboard. Once here make sure the tips of your wires, no more than half a centimeter, are clean without fray or corrosion. Now, you must solder the new battery in place with a soldering gun. Route the wires in the same fashion as the original battery. Once all connections are complete, sealed, and cooled down, it is time to but the device back together. Now try restarting your device, and enjoy the extended battery life!
Punteggio 0
Aggiungi la tua risposta
Javier Tandazo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 189
