Salta al contenuto principale
Released in 2015. Identified by model number MJS T2702.
How do I access data saved on my SD card?
I can't access an app that I have saved on my SD card. How do I access the information?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sounds to me like you need to install a free file manager. If your on a android device i recommend that you install es file explorer from the Google play
Punteggio 1
There are several reasons why you may be experiencing this issue. First, your SD card may be locked. To fix this, remove the card and make sure that the lock switch is not pushed all the way down into the lock position. Second, your SD card may not be supported by the device. To fix this, you can either purchase a card with a smaller GB storage or upgrade the software on your tablet. Third, your SD card could be damaged. If this is the case, the card will not be recognized by the device, making your apps inaccessible.
Punteggio 1
Aggiungi la tua risposta
Christina Montes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 173
