Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
No password or passcode
I recently purchased a phone from someone I do not know. When I turned it on it has a passcode still attached and I don't have the computer they used for iTunes to reset it like that. Is it possible to somehow reset it and start fresh?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi
I hope for your sake that the device is not locked to an iCloud account otherwise you're out of luck.
First i would recommend calling the local police station just to check to see if anyone has reported it stolen.
After that turn the device off, hold the home button down and plug it into a computer with iTunes on it and running, after a few moments it will recognise the device and it will ask you to either update or restore the device, pick restore, follow the prompts, it will take a while as it will download the OS for it. once it has finished the device should be ready to set up as a new device, if it is locked to an iCloud account it will ask you for the account information and currently theres no way around it that I am aware of.
good luck
Punteggio 0
Aggiungi la tua risposta
Amber sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 691
