Why does my left speaker sound muffled?
My iHome was working just a few hours ago but now when i play music, the left speaker doesn't seem to be playing at full volume. It also sounds muffled and I am not sure why.
Questa è una buona domanda?
Your woofer could be obstructed by something. Take the protective grill off of the front to make sure nothing is touching the driver. Also, check the hole on the back of the speaker casing to make sure there is no debris in there.
If nothing is obstructing the speaker, check to make sure the speaker is correctly connected to the motherboard. To access the motherboard, simply unscrew the large plastic cover on the bottom of the iHome system and remove the cover. Once the cover is off, make sure all the wires are connected correctly to the motherboard.
If everything is connected correctly, and nothing is obstructing the speaker, the speaker may be the problem. Visit the iHome iP1’s device page to view the guide on how to replace the woofers.
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,301
