Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
BSOD when turning off
when shutting down my phone it goes into a BSOD (blue screen of death). Also, the screen is non-responsive. However the screen is not damaged.
I have already drained and calibrated the battery
In recovery mode, performed 'update'
In recovery mode, performed 'restore'
none of the above seemed to have corrected the issue, any suggestions? I hate to replace the screen as there is no physical damage. Im not sure if it is software or hardware issue.
Questa è una buona domanda?
Punteggio 0
2 Commenti
are there any signs that the screen is gone does it have lines through it?
da
That is the strange thing; there are no signs that the screen is gone or has any lines through it.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Try new Proxy Sensor / Front Camera
Punteggio 1
1 Commento:
It was my son's friend's phone, he took it back before i was able to try replacing the proxy sensor/front camera.
da
Was the screen ever replaced? I've seen new screens cause similar problems.
Punteggio 1
1 Commento:
I don't believe that the screen was ever replaced. It was my son's friend so i'm not sure.
da
Aggiungi la tua risposta
eeuweske sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 57
