Salta al contenuto principale
Rilasciato a Gennaio 2015, l'XPS 13 ambisce ad essere il rivale commerciale del MacBookAir, con lo schermo senza bordi e il Touch-screen opzionale.
How can I repair/replace the jack input?
I damaged my jack input by tripping over the cable, and now I only have the left side of the stereo. I'd like to replace the jack input or to repair it, maybe with a soldering iron.
Thanks !
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You can replace the headphone jack, your challenge will be the soldering and locating the part. If you have a hot air station, you could replace it fairly easily. It's also possible with a good soldering iron, flux, and a solder sucker or wick.
If you're comfortable with the soldering part, you still need to locate the part. You can either look on aliexpress, as they have some headphone jacks listed for the XPS 13, or you could look on eBay for a XPS 13 motherboard thats broken, and transfer the headphone jack from that board.
Punteggio 2
Aggiungi la tua risposta
Malo Herry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 659
