Salta al contenuto principale
È la terza generazione dell console di gioco Xbox della Microsoft. Questa edizione è stata rilasciata il 22 novembre 2013.
My port to the HDMI is broken in the Xbox
My question is I broke the inside HDMI port for TV output from my Xbox one. Is there any Alternative way to play my xbox some how? If not where can I get the parts to fix it and is there a guide on that?
Questa è una buona domanda?
Punteggio 10
1 Commento
Can you not just take the HDMI in pass through port and desolated it and move it to the HDMI out port to make it work for now and fix hdmi in if you even care about it.
da
Aggiungi un commento
10 Risposte
Risposta Più Utile
If you search "Xbox One HDMI Port" on eBay, they have the part on there. There are also lots of videos on YouTube showing how to replace it.
I would warn you though, if you don't have experience in soldering, you could damage the main board trying to remove the old port. If you're not comfortable with the repair, it would be worth having an experienced tech do the soldering work for you.
Punteggio 3
1 Commento:
David is right. I fix lots of them where someone has tried to fix it but didn't know how. It ends up costing them a lot more because they tear the circuits traces off the motherboard.
I get that people like to fix stuff themselves but just be realistic with your abilities and tools.
da
If you get a hdmi to USB adapter can you not plug the hdmi cable in one of the Xbox’s usb slots?
Punteggio 1
9 Commenti:
Yes I would like to know this. I am trying to find a solution to my sons hdmi issue on his 1 yr old xbox minecraft edition
da
Yes i would like to know trying to see if i should buy one
da
Anyone ever try it?
da
I bought one offline and it isn’t working for me at all
da
Any luck with this yet?
da
Mostra altri 4 commenti
you should be able to get the parts here on I fix it but maybe radioshack or some other eletronuics bussiness
Punteggio 0
1 Commento:
ifixit does not sell those parts, nor does RadioShack or any other brick and mortar store that I know of. It's an online only part.
da
hdmi port replacement on xbox requires micro soldering and desoldering technique otherwise you will end up breaking the pads on logic board we have done many hdmi port replacement in our workshop for us it is easy if you live in new eland you can send it to us
Punteggio 0
1 Commento:
What is your workshop?
da
Get it from eBay like everyone said, or if you have a pc with windows ten, you can stream it directly to the pc and plug the controller to the pc or turn it on and play without it being plugged up to the TV
Punteggio 0
1 Commento:
Please elaborate on this .... I have the same problem
da
Yes I have the same broken hdmi slot
Punteggio 0
Can you not just take the HDMI IN pass through port and desolder it and move it to the HDMI OUT port to make it work for now and fix hdmi in if you even care about it.
Punteggio 0
i really wanted to get the Fortnite battle pass so iam sad
Punteggio 0
How can I play my Xbox one x if my HDMI is broken on my tv
Punteggio 0
connect a controller to your phone and do remote play through the xbox app
Punteggio -1
Aggiungi la tua risposta
Ryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 158
Tutti i Tempi: 70,735
